Chinese Lithium Battery for Victron Inverter System in Nigeria
I have a Victron Inverter system setup in Nigeria but I need a compatible chinese Lithium battery for the system. What are the chinese made brands available in Nigeria that will work well with the Victron setup. Thank you.
We need morel info! Wich Victron inverter? 12, 24 or 48 volts?
What is purpose of the inverter? Off grid Power or UPS function?
A good start is the battery compatibility list
Victron Multiplus Inverter, 48v, 5000kva and it is for Off-Grid. Presently using Tubular batteries on it. I just want to upgrade to Lithium battery. Thanks.
Thank you.
