Hello.
I am looking for a proper charger/inverter to be used with Eco-Worthy PowerMega 314 | 51.2V 314AH Lithium Battery 16kWh Source: https://www.eco-worthy.com/pages/2026-newin
Eco-Worthy support sent me this reply when I asked for the list of compatible chargers/inverters:
The 48V 314AH battery supports mainstream communication protocols including PACE RS485 Modbus, PYLON RS485 and Luxpowertek RS485. Communication can be established if your inverter supports any of these protocols.
General setup steps:
Set the battery type to Li-ion on the inverter, then select the battery brand as Pylon or LuxPower. Make sure the communication protocol configured on the battery CAN port matches the selected option.
I am looking for Victron advice on which Model of Multi-Plus II shall I choose?
The purpose of this setup will be to supplement the Enphase system (partial home sunlight backup - only a secondary backup load panel protected), that I have working, with the battery power for when the sun doesn’t shine. I am in the US and I am trying to stay away from Encharge 10T solution.
Thank you.
