Hi everyone
I m facing a problem with m’y charger bluesmart ip22 12/20
Well connected
Close to the 104Ah gel battery (50cm)
The battery is 15 months old and has always been connected with 250 watts solar pannels
I disconnected the solar pannels to change them so i plugged the charger and there it is
The charger gives me 14.4 V but my battery is still going low (dropping from 84%to 62% within 2 days)
I turned all the fuses off (lights,pump,…)so nothing should consume energy
Any ideas?
Thank you
Update : i reconnected the solar system and the mppt is on float,
Battery 100% straight after connection
13.78 V
Can someone explain that to me ?
Thanks again
