Blue smart ip 22 12/30 charger showing14.2 volts and shunt showing 13 volts
blue smart ip 22 12/30 charger showing14.2 volts and shunt showing 13 volts and battery is 70 % charged but is on absorption mode ps im a newbe
look for an open circuit, or high resistance point in the charging circuit.
sorry i sort of dont understand how a open or high resistance would cause the charger to show a higher voltage to the shunt or the mppt which both are the same have checked and all is tight
thanks elwyn
mike you were right i found a faulty fitting
thanks for all your help
Lose contact = high resistance. Once the charger starts, the charge current makes a voltage across that resistance that ADDS to the battery voltage - as seen by the charger.
