Charge EV from solar when battery is full
Hello, I have a Victron EV charger NS, solar panels and an AlphaESS battery. I would like to charge my EV from the solar panels when the battery is full. Could you please point me in the right direction? Thanks
Hi @hjkw3r4
Select Auto mode on EV Charger
Hi, thanks for your response.
Is it all I need? I don’t want the car to charge from the grid, only from solar, when the battery is full. I will use Home Assistant to get the charge level from the battery via their API, but not sure of how to work with the charger in Home Assistant.
Yes have a look at automatic mode in the manual it sounds like what you’re looking for but have a read to be sure.
I don’t know how home assistant victron add-on is setup. I use openhab and just get victron data via Mqtt.
