Changing charger parameters with Victron Connect in a split phase system
Yah, thanks. We typically don’t update the MPs; currently at v552, seems ok (would you agree? :thinking:).
I have been getting drop into PassThru mode when charging from the generator. Not too often, maybe once every week or two but PITA when it happens. Have to shut-down the entire system, which resets 37 devices and clocks and …:enraged_face:. I think the problem is I have Weak AC disabled in the charge settings. I want to turn it on, which is in fact what started this whole thing about updating the config :joy: The other reasons (like different charge settings) could wait until we’re back home in October. With my newfound knowledge now I will try changing Weak AC to on and seeing if that makes a difference.
