Ok, thank you, for CerboGx I found this Cumpara Cablu convertor USB - TTL serial cu 4 , Is it ok? I have to open GerboGx box and connect it as Venus OS: Root Access [Victron Energy] description.
YepâŚ
Anyway, wait for him to confirm, because, SoCs like Allwinner could have proprietary debug connectors on the SoC board itself.
I believe that this is the SoC module: Einstein-A20 â CubieTech
Anyway, an adapter like that (USB to serial) is a good thing to have for a enthusiast DIYer, not to mention that it may work OK for the purpose, only the place for connection to be different. ![]()
itâs cheap, I ordered one, just for fun, Itâs good to have around the house
Please be aware this is a rather exceptional situation. I would like to understand what is going on and George would like to keep his system running. Normally you would just get it back to your dealer / installer (if it is under warranty), well and reinstall it first. @GeorgeD Donât reinstall this unit though. We are going to do low level debugging or you can return the unit, so we can find out what is going on here.
BTW⌠Maybe this could be relatedâŚ
I have a RPI3B+ for testing. It had 3.32.
Updated from itâs firmware - online updates page to 3.70.
Went OK and worked OK.
Rebooted from the firmware - stored backup page back to 3.32.
After reboot, there is no 3.70 alternative in the firmware - stored backup page, like was never installed.
Is this normal behavior or the firmware should be there both?
Didnât mind up until now, Iâve take it as it is, but seeing this thread I wonderâŚ
That is expected behavior. 3.32 canât mount the newer ext partition, since it got a new feature flag. So it is unable to verify if there is a valid backup image and what its version is.
Thanks for confirming it.
This flag is from 3.70 or some version before?
Which version is the milestone for swapping back?
Thanks again for taking the time for sharing details!
v3.60 introduced it. v3.60 should be able to report the v3.70 backup image.
