Cerbo GX - temperature sensor connection
Hello - I have the Victron temperature sensor and want to connect it to the Cerbo GX however I do not have the female connector to plug into the Cerbo GX temp ports and cannot find what type of connector I need. Any guidance on what type of connector would be greatly appreicated. Thank you.
The Victron Temp. sensors that comes with my MP2s was complete equipped: sensor-cable-plug.
Can you please post a photo of your Victron sensor?
I want to use the temperature sensor to trigger one of the relays in n the Cerbo GX to turn on a cooling fan when the battery compartment gets above 90 degrees. I am not trying to connect the sensor to the Multiplus II, my Lithionics BMS addresses battery module temperature.
Oh sorry, I remembered this wrong. :upside_down_face:
The clamping blocks are included in the scope of delivery of the gx device.
I have connected the Temp. sensor cables to the clamping block and then to the gx ports. The absolute value of measurment can be adjusted within the gx gui if it is not correct.
I’m using the three Temp. sensors, bought three MP2s, to measure the Temp. in my batterie case (bottom and top) and the environment of the Victron MP2 wall.
Hint: Delete your gx label photo or make it illegible. To many secrets.
