Cerbo GX Screen Not Working, can't cancel alarms!
Hi everyone,
The LCD screen for my Cerbo GX froze and then went totally blank. Without the touchscreen I can’t cancel the “grid lost alarm.” Now whenever I’m not hooked into shore power, I’m either stuck listening to the alarm beep, or I have to plug a running laptop into the MK3 USB interface just to stop the beeping.
Here’s what I’ve tried so far:
  • Power-cycling the Cerbo GX
  • Plugging the touchscreen into different USB ports on the Cerbo
  • Reseating the HDMI cable
  • Checking the visible cabling (looks like the install used extenders – the USB and HDMI cables are separate for the last 3–4 feet but I can’t see the full run)
None of that fixed the issue.
Other notes:
  • This system is in a 25fb Tradewind Airstream.
  • VRMConnect doesn’t help – the Bluetooth connection always fails.
  • Without the touchscreen, I don’t know how I’d connect the system to Wi-Fi for remote access.
Has anyone run into this before, or is there a workaround to silence alarms and access settings without a working screen? Any troubleshooting advice would be much appreciated!
Thanks in advance!
The extender certainly could be the issue - extending the GX Touch’s cabling is expressly not supported and known to cause issues.
That said, Remote Console should get you into the Cerbo to be able to silence / turn off alarms: 8. Accessing the GX device
was able to use my starlink as a router and disable audible alarms! Thanks!
