Cerbo GX MK3 – unexpectedly low wired temperature readings on Venus OS Large v3.85
I’m seeing unexpectedly low readings from all four wired temperature sensors on my Cerbo GX MK3, running the official release of Venus OS Large v3.85. In the Remote Console, the four inputs initially showed temperatures between −10.7°C and −8.9°C.
The same sensors worked correctly in the same configuration on my Cerbo GX MK2. When I upgraded to the MK3, I moved them over without changing any connectors.
For a separate test, I disconnected all four sensors and connected a single original Victron temperature sensor directly to Temperature Input 1. The reading first dropped to −2.5°C and later reached −7°C. I estimated the temperature at the test location to be around +4 to +5°C.
Has anyone seen similar readings on a Cerbo GX MK3 running v3.85? Is this a known issue, or are there any diagnostic checks you’d suggest to narrow down the cause?
Thanks,
Krzysztof
