Cerbo GX 3.80~33 and Shelly miniEM gen4
I have a Cerbo GX with VenusOS 3.80~33 in my camper.
I didn’t install the multiplus because of the weight.
Aldo I installed a Victron battery Smart charger IP22 for charging a LifPo4 and a IP65 to charge the starterbattery
at the 230v inlet I connected a shelly miniEMgen4.
it is detected by the Cerbo GX and monitors what I use from external power
Is there a way to add this into the overview? that way I always have a view how many power I use from the grid
Even in 3.80 beta it is somewhat limited directly in the Cerbo UI.
I created a virtual meter in Node-Red for it. You can then tell it to
act as a grid meter.
This is an example:
I used it as EVCS meter here.
