My system
Quattro 10000/48v grid on AC 1 in Load on AC 1 out, this include SMA
Cerbo GX
150/35 MPPT, 800watt input
SMA 4000, PV inverter 3600 input
FZSnick battery
Victron EV charger
AC Current Meter on SMA, active is threaded through the meter.
All devices have the latest firmware
In the Cerbo GX display, it show the current meter as output OK, but the AC load shows the PV output plus a small AC input. As I think the PV output should show up as feeding the grid and the system should also be keeping the battery charger, form the PV output, which the Cerbo is not showing.
The current meter is set with the dip switches for 5KW, and wired into the AUX 1 input of the Quattro.
Any ideas on the issue.
Paul
