why isn’t the charger’s data correct ?
Why the battery is at 100% in the charger and different value on the VRM ?
what am I setting wrong ?
Why the battery is at 100% - because you have the virtual battery enabled
why isn’t the charger’s data correct - because the power factor of the charger of the vehicle is not 1. In the settings, you can calibrate it
how do I find out what the vehicle will do? The vehicle is a Volvo EX30 2024.
or how to compare it to make the consumption ok?
The calibration doesn’t help somehow wouldn’t it be better to make the calibration last for a longer period of time ? so that the charger can test everything and calibrate itself ?
Otherwise I praise the new update for the possibility of charging 6A it’s great 10A was too much ![]()
I don’t understand what you mean with 6A and 10A
