Can't figure out how to disable charging without disconnecting from grid in Node-Red
Hey everyone,
The problem:
I know there are already some similar questions on this topic, but none of the proposed solutions seem to work or are available to me.
What I have already found and tried:
  • Set “DVCC Charge current limit (A)” to 0
    • ESS Control Node > Victron Settings > DVCC Charge current limit (A)
    • This value gets ignored and the limit set in the system via the VictronConnect APP is used
    • Note: DVCC is disabled on my system
  • Set “Max charge power (W)” to 0
    • ESS Control Node > Victron Settings > Max charge power (W)
    • This value also gets ignored
  • Set “/Dc/0/MaxChargeCurrent”
    • Cannot find it (I looked in the “Custom Control Node”)
  • Set “MaxChargeCurrent”
    • Custom Control Node > com.victronenergy.settings > /Settings/SystemSetup/MaxChargeCurrent
    • Doesn’t seem to do anything
I did hit upon this page which states that for Mode 2:
The available control points are:
  • Grid power setpoint
  • Enable/Disable charge
  • Enable/Disable inverter
My system is currently set to Mode 1. Could that be what’s blocking the settings from changing?
My goal:
I would like my batteries to only charge on solar. However, I cannot disconnect from the grid because if my solar production is in excess of what I need, I need somewhere for that energy to go, in this case to the grid. So disabling the charger would be perfect.
System details:
  • Multiplus-II 24/5000/120
  • Raspberry PI running Venus v3.67
Haven’t found a way directly yet besides manipulating the charge current control assistant with a relay from the gx and node red.
There are couple of threads with this same discussion/question
you shouldnt change charge current, you have to change desired SOC
If actual SOC is at 75% and you set set desired SOC to 75% charging will stop
Where do I find that setting?
        "id": "df865c790f63cc2c",
        "type": "victron-input-custom",
        "z": "24afc61f87e8849c",
        "g": "4f345968900b1aed",
        "service": "com.victronenergy.vebus/275",
        "path": "/Dc/0/MaxChargeCurrent",
        "serviceObj": {
            "name": "MultiPlus II Inverter (275)"
        "pathObj": {
            "name": "/Dc/0/MaxChargeCurrent",
            "type": "number",
            "value": 25
        "name": "",
        "onlyChanges": true,
        "x": 270,
        "y": 160,
        "wires": [
        "id": "04948dbe7c141a48",
        "type": "victron-output-custom",
        "serviceObj": {
            "name": "MultiPlus-II (275)"
        "pathObj": {
            "type": "number",
            "value": 70
        "name": "",
        "onlyChanges": false,
        "x": 250,
        "y": 80,
        "wires": []
        "id": "da1b5c1c72c666ce",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "0",
        "payloadType": "num",
        "x": 150,
        "y": 120,
        "wires": [
                "04948dbe7c141a48"
        "id": "6622999de991cb68",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "70",
        "x": 430,
        "y": 120,
        "wires": [
                "04948dbe7c141a48"
        "id": "0684a1157a766f9d",
        "type": "inject",
        "name": "",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "45",
        "x": 290,
        "y": 120,
        "wires": [
                "04948dbe7c141a48"
        "id": "4d6ba343dfac968f",
        "type": "global-config",
        "env": [],
        "modules": {
            "@victronenergy/node-red-contrib-victron": "1.6.58"
Assuming you run DESS:
This flow allows to set a delta soc% that gets applied automatically on the incomming VRM DESS schedules. Investigate the nodes to adjust for your own needs. The top group sets the delta as a flow context, the bottom group ensures it gets applied. Do check your global context for actual values.
        "id": "e93a0fa19b4e94ef",
        "type": "tab",
        "label": "Flow 2",
        "disabled": false,
        "info": "",
        "env": []
        "id": "27fed8e81887d874",
        "type": "group",
        "z": "e93a0fa19b4e94ef",
        "style": {
            "stroke": "#999999",
            "stroke-opacity": "1",
            "fill": "none",
            "fill-opacity": "1",
            "label": true,
            "label-position": "nw",
            "color": "#a4a4a4"
        "nodes": [
            "43fa078f81e6fa6f",
            "4aae368ab867b8f6",
            "71e664fe7182c8f2",
            "dbfdaf7da41ef7bb"
        "x": 34,
        "y": 59,
        "w": 312,
        "h": 202
        "id": "9504f31c551cc3a9",
        "type": "group",
        "name": "",
        "style": {
            "label": true
        "nodes": [
            "c9baf80caa93fa03",
            "aca4b11c7ac18285",
            "5cb62589afec2953",
            "3acb6ac480a02760",
            "8af1075a74576018",
            "9490322c533ea958",
            "50af02f13e7b8112",
            "b375a024a1a9ef7d",
            "66e15f194b62a720",
            "0ce74f090bd7de6e",
            "6eb949b72c34414c",
            "2e8474e9f6751c08",
            "42c0403e761125cd",
            "953c4fc7d001b890",
            "d6bd73e5a2728fbd",
            "e0139ce044c9a926",
            "29cea0d1812b449c",
            "bd98a337fb0bf49d",
            "20e8af3527a9cbb5",
            "505a3c60e984f7ff",
            "7bd9f7a9b6ad90a3",
            "95e48bc77caa556c",
            "82479aa49217f710",
            "43e94cdf4fbd1c62",
            "431282b8c7c140e8",
            "ccb5188ea1274b5b",
            "3b2333787a589d86",
            "3fe61940029e593b",
            "4cc42e925cacff6d",
            "e651a6db5d649b4c",
            "a964039ac341f40e",
            "5bfc79b4c9c9c3aa",
            "209aed5e4690e8fc",
            "c898bd869e1e680b"
        "x": 34,
        "y": 299,
        "w": 1452,
        "h": 242
        "id": "29cea0d1812b449c",
        "type": "junction",
        "g": "9504f31c551cc3a9",
        "x": 1460,
        "y": 340,
        "wires": [
        "id": "c898bd869e1e680b",
        "type": "junction",
        "x": 1460,
        "y": 440,
        "wires": [
        "id": "43fa078f81e6fa6f",
        "type": "inject",
        "g": "27fed8e81887d874",
        "name": "+0.50",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "delta",
        "payload": "0.50",
        "x": 130,
        "y": 100,
        "wires": [
                "dbfdaf7da41ef7bb"
        "id": "4aae368ab867b8f6",
        "type": "inject",
        "name": "+0.00",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "delta",
        "payload": "0.00",
        "x": 130,
        "y": 160,
        "wires": [
                "dbfdaf7da41ef7bb"
        "id": "71e664fe7182c8f2",
        "type": "inject",
        "name": "-0.50",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "delta",
        "payload": "-0.50",
        "x": 130,
        "y": 220,
        "wires": [
                "dbfdaf7da41ef7bb"
        "id": "dbfdaf7da41ef7bb",
        "type": "function",
        "name": "dsoc",
        "func": "let ts = Date.now();\n\nlet dsoc = msg.payload;\nflow.set( 'dsoc', dsoc );\n\nlet fill = 'grey';\nif ( dsoc > 0 ) { fill = 'green'; }\nif ( dsoc < 0 ) { fill = 'blue'; }\nlet shape = 'dot';\nlet text = ( dsoc + ' @ ' + ts );\nnode.status( { fill, shape, text } );\n\nmsg.topic = 'dsoc';\nmsg.ts = ts;\n//msg.payload = dsoc;\n\nreturn msg;",
        "outputs": 1,
        "timeout": 0,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 270,
        "y": 160,
        "wires": [
        "id": "c9baf80caa93fa03",
        "service": "com.victronenergy.settings",
        "path": "/Settings/DynamicEss/Schedule/0/TargetSoc",
        "serviceObj": {
            "name": "com.victronenergy.settings"
        "pathObj": {
            "name": "/Settings/DynamicEss/Schedule/0/TargetSoc",
            "type": "number",
            "value": 27.53
        "name": "dbsTSoC0",
        "roundValues": "no",
        "rateLimit": "0",
        "x": 120,
        "y": 340,
        "wires": [
                "29cea0d1812b449c",
                "ccb5188ea1274b5b"
        "id": "aca4b11c7ac18285",
        "path": "/Settings/DynamicEss/Schedule/1/TargetSoc",
        "serviceObj": {
        "pathObj": {
            "name": "/Settings/DynamicEss/Schedule/1/TargetSoc",
            "type": "number",
            "value": 25.95
        "name": "dbsTSoC1",
        "rateLimit": "0",
        "x": 300,
        "y": 340,
        "wires": [
                "29cea0d1812b449c",
                "3b2333787a589d86"
        "id": "5cb62589afec2953",
        "path": "/Settings/DynamicEss/Schedule/2/TargetSoc",
        "serviceObj": {
        "pathObj": {
            "name": "/Settings/DynamicEss/Schedule/2/TargetSoc",
            "type": "number",
            "value": 24.36
        "name": "dbsTSoC2",
        "rateLimit": "0",
        "x": 480,
        "y": 340,
        "wires": [
                "29cea0d1812b449c",
                "3fe61940029e593b"
        "id": "3acb6ac480a02760",
        "path": "/Settings/DynamicEss/Schedule/3/TargetSoc",
        "serviceObj": {
        "pathObj": {
            "name": "/Settings/DynamicEss/Schedule/3/TargetSoc",
            "type": "number",
            "value": 22.78
        "name": "dbsTSoC3",
        "rateLimit": "0",
        "x": 660,
        "y": 340,
        "wires": [
                "29cea0d1812b449c",
                "4cc42e925cacff6d"
        "id": "8af1075a74576018",
        "path": "/Settings/DynamicEss/Schedule/4/TargetSoc",
        "serviceObj": {
        "pathObj": {
            "name": "/Settings/DynamicEss/Schedule/4/TargetSoc",
            "type": "number",
            "value": 21.2
        "name": "dbsTSoC4",
        "rateLimit": "0",
        "x": 840,
        "y": 340,
        "wires": [
                "29cea0d1812b449c",
                "e651a6db5d649b4c"
        "id": "9490322c533ea958",
        "path": "/Settings/DynamicEss/Schedule/5/TargetSoc",
        "serviceObj": {
        "pathObj": {
            "name": "/Settings/DynamicEss/Schedule/5/TargetSoc",
            "type": "number",
            "value": 20.65
        "name": "dbsTSoC5",
        "rateLimit": "0",
        "x": 1020,
        "y": 340,
        "wires": [
                "29cea0d1812b449c",
                "a964039ac341f40e"
        "id": "50af02f13e7b8112",
        "path": "/Settings/DynamicEss/Schedule/6/TargetSoc",
        "serviceObj": {
        "pathObj": {
            "name": "/Settings/DynamicEss/Schedule/6/TargetSoc",
            "type": "number",
            "value": 20.1
        "name": "dbsTSoC6",
        "rateLimit": "0",
        "x": 1200,
        "y": 340,
        "wires": [
                "29cea0d1812b449c",
                "5bfc79b4c9c9c3aa"
        "id": "b375a024a1a9ef7d",
        "path": "/Settings/DynamicEss/Schedule/7/TargetSoc",
        "serviceObj": {
        "pathObj": {
            "name": "/Settings/DynamicEss/Schedule/7/TargetSoc",
            "type": "number",
            "value": 19.55
        "name": "dbsTSoC7",
        "rateLimit": "0",
        "x": 1380,
        "y": 340,
        "wires": [
                "29cea0d1812b449c",
                "209aed5e4690e8fc"
        "id": "66e15f194b62a720",
        "serviceObj": {
        "pathObj": {
            "type": "number",
            "value": 47.79
        "name": "dbsTSoC4",
        "x": 850,
        "y": 500,
        "wires": []
        "id": "0ce74f090bd7de6e",
        "serviceObj": {
        "pathObj": {
            "type": "number",
            "value": 49.56
        "name": "dbsTSoC5",
        "x": 1030,
        "y": 500,
        "wires": []
        "id": "6eb949b72c34414c",
        "serviceObj": {
        "pathObj": {
            "type": "number",
            "value": 51.33
        "name": "dbsTSoC6",
        "x": 1210,
        "y": 500,
        "wires": []
        "id": "2e8474e9f6751c08",
        "serviceObj": {
        "pathObj": {
            "type": "number",
            "value": 53.1
        "name": "dbsTSoC7",
        "x": 1390,
        "y": 500,
        "wires": []
        "id": "42c0403e761125cd",
        "serviceObj": {
        "pathObj": {
            "type": "number",
            "value": 40.15
        "name": "dbsTSoC0",
        "x": 130,
        "y": 500,
        "wires": []
        "id": "953c4fc7d001b890",
        "serviceObj": {
        "pathObj": {
            "type": "number",
            "value": 42.11
        "name": "dbsTSoC1",
        "x": 310,
        "y": 500,
        "wires": []
        "id": "d6bd73e5a2728fbd",
        "serviceObj": {
        "pathObj": {
            "type": "number",
            "value": 44.06
        "name": "dbsTSoC2",
        "x": 490,
        "y": 500,
        "wires": []
        "id": "e0139ce044c9a926",
        "serviceObj": {
        "pathObj": {
            "type": "number",
            "value": 46.02
        "name": "dbsTSoC3",
        "x": 670,
        "y": 500,
        "wires": []
        "id": "bd98a337fb0bf49d",
        "type": "function",
        "name": "dsoc",
        "func": "let ts = Date.now();\nmsg.ts = ts;\n\nlet dsoc = flow.get( 'dsoc' );\nlet soc = msg.payload + dsoc;\n\nif ( soc > 100 ) {\n    soc = 100;\n} else if ( soc < 0 ) {\n    soc  = 0;\n}\n\nlet fill = 'grey';\nif ( dsoc > 0 ) { fill = 'green'; }\nif ( dsoc < 0 ) { fill = 'blue'; }\nlet shape = 'dot';\nlet text = ( dsoc + ' @ ' + ts );\nnode.status( { fill, shape, text } );\n\nmsg.topic = 'soc';\nmsg.payload = soc;\n\nreturn msg;",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1370,
        "y": 440,
        "wires": [
                "2e8474e9f6751c08",
                "c898bd869e1e680b"
        "id": "20e8af3527a9cbb5",
        "type": "function",
        "name": "dsoc",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 110,
        "y": 440,
        "wires": [
                "42c0403e761125cd",
                "c898bd869e1e680b"
        "id": "505a3c60e984f7ff",
        "type": "function",
        "name": "dsoc",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 290,
        "y": 440,
        "wires": [
                "953c4fc7d001b890",
                "c898bd869e1e680b"
        "id": "7bd9f7a9b6ad90a3",
        "type": "function",
        "name": "dsoc",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 470,
        "y": 440,
        "wires": [
                "d6bd73e5a2728fbd",
                "c898bd869e1e680b"
        "id": "95e48bc77caa556c",
        "type": "function",
        "name": "dsoc",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 650,
        "y": 440,
        "wires": [
                "e0139ce044c9a926",
                "c898bd869e1e680b"
        "id": "82479aa49217f710",
        "type": "function",
        "name": "dsoc",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 830,
        "y": 440,
        "wires": [
                "66e15f194b62a720",
                "c898bd869e1e680b"
        "id": "43e94cdf4fbd1c62",
        "type": "function",
        "name": "dsoc",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1010,
        "y": 440,
        "wires": [
                "0ce74f090bd7de6e",
                "c898bd869e1e680b"
        "id": "431282b8c7c140e8",
        "type": "function",
        "name": "dsoc",
        "outputs": 1,
        "timeout": "",
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 1190,
        "y": 440,
        "wires": [
                "6eb949b72c34414c",
                "c898bd869e1e680b"
        "id": "ccb5188ea1274b5b",
        "type": "delay",
        "name": "1/s",
        "pauseType": "rate",
        "timeout": "1",
        "timeoutUnits": "seconds",
        "rate": "1",
        "nbRateUnits": "1",
        "rateUnits": "second",
        "randomFirst": "1",
        "randomLast": "5",
        "randomUnits": "seconds",
        "drop": true,
        "allowrate": false,
        "outputs": 1,
        "x": 110,
        "y": 400,
        "wires": [
                "20e8af3527a9cbb5"
        "id": "3b2333787a589d86",
        "type": "delay",
        "name": "1/s",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": true,
        "allowrate": false,
        "outputs": 1,
        "x": 290,
        "y": 400,
        "wires": [
                "505a3c60e984f7ff"
        "id": "3fe61940029e593b",
        "type": "delay",
        "name": "1/s",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": true,
        "allowrate": false,
        "outputs": 1,
        "x": 470,
        "y": 400,
        "wires": [
                "7bd9f7a9b6ad90a3"
        "id": "4cc42e925cacff6d",
        "type": "delay",
        "name": "1/s",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": true,
        "allowrate": false,
        "outputs": 1,
        "x": 650,
        "y": 400,
        "wires": [
                "95e48bc77caa556c"
        "id": "e651a6db5d649b4c",
        "type": "delay",
        "name": "1/s",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": true,
        "allowrate": false,
        "outputs": 1,
        "x": 830,
        "y": 400,
        "wires": [
                "82479aa49217f710"
        "id": "a964039ac341f40e",
        "type": "delay",
        "name": "1/s",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": true,
        "allowrate": false,
        "outputs": 1,
        "x": 1010,
        "y": 400,
        "wires": [
                "43e94cdf4fbd1c62"
        "id": "5bfc79b4c9c9c3aa",
        "type": "delay",
        "name": "1/s",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": true,
        "allowrate": false,
        "outputs": 1,
        "x": 1190,
        "y": 400,
        "wires": [
                "431282b8c7c140e8"
        "id": "209aed5e4690e8fc",
        "type": "delay",
        "name": "1/s",
        "timeout": "1",
        "rate": "1",
        "nbRateUnits": "1",
        "randomFirst": "1",
        "randomLast": "5",
        "drop": true,
        "allowrate": false,
        "outputs": 1,
        "x": 1370,
        "y": 400,
        "wires": [
                "bd98a337fb0bf49d"
        "id": "d2e38ea93147fd68",
        "env": [],
        "modules": {
I’m not using DESS at the moment
That should simplify your use-case.
This should do: Can't figure out how to disable charging without disconnecting from grid in Node-Red - #5 by UpCycleElectric
Victron enables layers upon layers of functional system abstractions. Above settings allow you to set the maximum charging current to zero at the lowest level (on the MP-II).
Ess system settings. The victron nodes will have options.
Alright, after some trial and error I finally have it working.
  • I had to install and configure the ESS Assistant using the VEConfiguration software
  • I used Node-RED to set ESS Mode to 2
    • ESS Control Node > ESS: Venus Settings > Measurement: ESS Mode
  • Then I can control charging by setting the “Max Charge Power”
    • ESS Control Node > ESS: Venus Settings > Measurement: Max Charge Power (W)
I currently set the Max Charge Power to a bit less than my AC-Out value (which is negative when the solar charger is producing), just to prevent feed-in from the grid.
Some notes:
  • Setting Max Charge Power to 0 disables charging
  • Setting Max Charge Power to a negative value it will show an error and will be ignored
  • The Multiplus will not charge at a higher rate than the set Charge Current (Under “Charger” in the Victron Connect App)
