JPV
(JPV)
21 June 2025 22:10
1
This is how I have wired up 2 x 100 ah batteries, inside a sealed battery box to achieve 12 volts 200amp
I just not sure if this is correct
Or this other option is preferred,
IE
Battery 2 + to Battery 1 +
Battery 1 - to Battery 2 -
Battery 1 + to busbar
Battery 2 - to shunt
would love some feed back
Your first drawing is OK. The only comment is why not connect the ac charger to the bus bar. It has 2 outputs but as the batteries are in parallel they do not need the separate feeds. The wire from busbar to battery needs to be large enough.
JPV
(JPV)
21 June 2025 22:49
4
@pwfarnell
Thoughts on
or
Battery 1 + to Battery box +
Battery 2 + to battery box +
Battery 1 - to battery box -
Battery 2 - to battery box 1
is still okay for obtaining 200ah evenly over both batteries
What about fuses and on/off switch?
On your revised drawing as long as the 4 battery wires are the same length charging will be uniform
See https://www.victronenergy.com/upload/documents/Wiring-Unlimited-EN.pdf
JPV
(JPV)
22 June 2025 23:59
7
Fused to the eyeballs with circuit brakers and battery on/off switch
JPV
(JPV)
23 June 2025 00:01
8
@pwfarnell
Thank you …yet again especially for the link
Greatly appreciated
Just a DC DC and 2000w inverter to go
system
(system)
Closed
7 July 2025 00:01
9
