Hi, currently i have three 100Ah batteries connected to a Cerbo on a boat. When the boat is not in use only the Cerbo (with 4G LTE) is drawing power which is a very small load of <0.5A. The BMS in these batteries unfortunately does not monitor loads under 1 to 1.5A. So they won’t notice the power draw, don’t update the SoC and will prevent the batteries from being charged (CCL = 0A). In about three weeks the batteries are drained to <10%. A workaround is initiating a higher load, like turning on the multiplus inverter, this will be noticed and the BMS resets itself, lowering the SoC and increasing CCL so they can be charged again.
I am planning to change this setup to: 2x Victron 200Ah NG + the BMS 500 NG. In order to monitor these small current flows and change SoC and CCL accordingly.
Will the Victron Lithium 12V/200Ah + Lynx BMS 500 NG monitor small currents, like 0,1A? Adapt the SoC accordingly and allow charging?
The simple answer is yes, the specigied current limit is 0.05A. Do not forget the BMS has a current draw of around 0.2A at 12V when on to hold the contactor open.
I have a boat with 2 x 300Ah 12V NG batteries and Lynx NG 500 BMS. All I have running during the winter is the Router on 12V, the Cerbo, GX Tank 140, and tank senders, MPPT, thermostat plus the BMS and Smart Battery Protect. I read amperage down to 0.1A. What I tend to see is that the SOC error is slightly downwards, I.e. in the safe direction.
Wouldn’t a Ve.Bus BMS NG (or the just announced Ve.CAN BMS NG) be a good alternative?
It doesn’t have the 0.2A current draw (which also adds up over 3-4 weeks). And i am not sure what the use of the contactor on a boat has (in my 12V system only Cerbo and the heater are directly powered, the rest is behind the main switch). It might need a smartshunt in front of it, but that has an even higher accuracy of sensing small loads. Together they are also a third of the price. That said the Lynx integrator as part of the integrator/power-in rails looks really solid . Any thoughts?
