I have been searching high and low for an answer to this.
The Grafana instructions specify a GX device needs to be used since MQTT is a requirement.
Is it possible to use Grafana with a GlobalLink 520?
Thanks in advance
Thanks in advance
Currently the GlobalLink 520 does not support MQTT and thus is not compatible with the self-hosted Victron Grafana dashboarding solution.
thank you
