If I look at the manual for the MPPT 100/20 it says that the cable size must be 6mm² / AWG10. For both PV and Battery the same.
It’s the same size as for all his other smaller brothers.
Isn’t it better to use a thicker cable for the battery connection?
The terminals on the 100/20 look suitable for cables bigger than 2,5mm diameter (6mm²).
Does anyone have the exact specs / diameter of the terminals on the 100/20?
Thanks!
