Bug EVCharger graphic energyflow
small bug, in web page of EV Charger is displayed reverse flow of energy betwen inverter and battery, inverter quattro, island system
Hi @Luborson,
It could be a bug in the BMS, which sends incorrect (reversed) data. What BMS do you use?
P.S. I faced that bug in a JK BMS.
P.P.S. You can check it in Node-Red— just print the data from the BMS to the log.
Hello, I use Pylontech US3000C, but in cerbo and VRM is correct
