Bonded Neutral Generator GFCI Ground Fault
I have a Ford F150 with 7.2kW ProPower onboard. It is a 7.2 kW 30/220 generator/inverter option on the Lightning EV or the PowerBoost Hybrid. It is a very sensitive neutral-bonded GFI system.
When attempting to use it as a backup generator for a house via interlock or “standard” manual transfer switch the system generates a ground fault error and shuts down. There are ad nauseum discussions on the subject:
https://tinyurl.com/327y5nkw
The “proper” suggested fix is a neutral switching transfer switch like the Generac 6852 transfer switch:
The most often used “fix” is just to remove the ground at home inlet or make a pigtail with ground removed for the generator power cord.
After all that background…
I am building a home backup system using split phase Quattros and would like to use my Pro Power generator as a secondary AC source.
  1. Can the Quattros be programmed with switching neutral ?
  2. Will the second method of removing ground at power inlet or cord generate error @ Quattros ?
Hi @fwunder
Quattro has it’s own ground relay that can be selected to do what you want. By default even, unless you deselect it. So you shouldn’t need to fiddle with anything external, but it shouldn’t be fazed if you did.
Thanks @ JohnC
Unfortunately, I have gathered enough anecdotal evidence the the Ford Pro Power system cannot be used as a power source with the Quattro. From one user with a system almost exactly what I want to build:
I used the F-150 Lightning as the generator back up for this system. I dealt with the exact issues that you described. The Quattros disconnect the neutral ground bond during connection to generator, unfortunately the Lightning senses this bond and disables power to the outlet until the bond is sensed to be open. This you find yourself in the chicken and egg cycle with no way out.
This follows the same scenario users have reported using the Ford system with home transfer switch or panel interlock.
Alternatively, I did gather evidence suggesting a Eg4 Chargeverter GC can be used and may be a better solution for battery bank offgrid charging due to its support for a wide range of generator input.
I found an amazingly easy fix.
Here it is for a Multiplus II:
Go to Victron app on phone.
Go to settings
Touch Upper corner where it say ON
Drop down- say CHARGER ONLY.
DONE!
The way the Victron is designed, it goes thru the inverter when it does not need to, but Victron designed this way for other configuration as I understand it. By turning off inverter, it goes and charges or powers what you want cleanly bypassing the inverter.
An inverter is not needed to charge the battery, only invert 12v into 120v. So the PowerBoost cannot sync with the Victron inverter and gives the error. The PowerBoost only need to go thru the converter side 120v to 12v.
Also, while charging the 120v stays powering as it bypasses the inverter and lets the 120 thru.
Air conditioner and lithium battery, ebikes, all run and charge great from RV outlets.
Now enjoy the real value of PowerBoost!
