Bmv-712smart settings for Yuasa swl2500 batteries
Hi I have recently replaced my 5 basic 110ah domestic batteries with 5 96ah Yuasa swl2500tfr gell batteries.
I am struggling to set the battery setting on the BMV correctly. I would appreciate any help . I have a 12v system.
my current settings are
capacity 480 ah
charged voltage 13.2 volts
current measurement direction normal
discharge floor 20%
tail current 4.00%
charged detection time 3min
Peukert exponant 1.25
charge efficiency factor 99%
current threshold 0.10A
time to go averaging period 3min
battery soc on reset clear
synchronize soc to 100 synchronize
zero current calibration calibrate
battery spec
Yuasa Technical Data Sheet Yuasa SWL2500TFR Industrial VRLA Battery Layout Specification
Nominal voltage (V) 12
20-hr rate Capacity to 1.75V/Cell at 20°C (Ah) 93.6
Float voltage at 20deg C 13.65V
discharge power at 20 deg C to 9.6V 2500W
I would increase your Charged voltage to 13.6V, and the charged time to 1 hour. With your settings, the BMV will reset to 100% while the battery is still charging.
Possibly also increase the tail current to 10%, allowing 2% for each battery, with 5 in parallel.
