BMV-712 settings AGM batteries
What are the best settings with (3) Victron Super Cycle AGM batteries 170ah each and a Centaur 12/100 charger?
Battery capacity 510Ah
Charged voltage 0.2V below the absorption voltage set on the Centuar
Tail current 2% o start with and see how it works vs the Centuar
Peukert coefficient 1.15
Charged efficiency 95%
Discharge floor 50%
Anything else, leave at the default setting.
Towards the bottom there is a setting around the SOC, set this to remember last value or words to that effect so if it loses power it remembers the SOC when it is reconnected.
Thanks! I was close. One more question. How do I evaluate the tail current setting?
Best Regards
Carlos Contreras
V1sion Trimaran
+1 [contact info removed for security]
V1 The speed of a jet on take off, at which there is no longer enough runway left to stop safely.
Therefore committed to flight..
Partly it depends on your charger settings and partly how your batteries behave. I had a bank of the Victron AGM Telecom batteries, similar performance to the Super Cycle ones and I ended up with my BMV set at 1% tail current and the solar charger at 0.8% tail current. The charger has to have a lower tail current than your BMV as the charger has to stop absorption AFTER the BMV has synchronised to 100%. In terms of what tail current to use, the only way is to monitor what happens if you have a longer absorption, if the current falls to say 1.5% and goes no lower than your tail current settings have to be higher than this in both your charger and your BMV. So it is trial and error and as @Ludo says, gut feeling from experience.
