After installing new LiFePo batteries in our van the BMV 700 has stopped counting amps. Voltage and amps readings are correct but it’s not counting amps.
Unit was reprogrammed to new amp hour setting, also did a full reset (setup+select for 3 seconds) and powered it down for a few minutes. Nothing else changed in the wiring. Same shunt, etc. Any help would be appreciated.
Phil
