BMS communication via MQTT to Victron GX
At this moment my BMS is not (yet) coupled to the Victron. So I’m looking for an optimal way to do so.
If my BMS would communicate via MQTT all its data, is there an option to use that data in the Victron Multiplus II GX?
For example via https://github.com/syssi/esphome-jk-bms
I already use the MQTT path to readout my energy sensor.
The extra advantage of this is that there is no electrical path between the BMS and the Victron.
