I have a Cerbo GX setup in my motorhome with Ruuvi and Mopeka sensorn connected. This setup has been working fine with beta versions including 3.60~59, but upgrading to 3.60~66 and ~69 it no longer finds the bluetooth adapter, hence not the sensors eigther.
Neigther can the Victron Connect app find the Cerbo any longer.
The system runs a DVCC setup with an MPPT 100/30, an IP22, an Orion XS dc/dc, all connected via VE.direct/USB and an 123Electric BMS via USB . No WiFi enabled.
Disabling/enabling BT, even with a reboot inbetween, does not help.
Any suggestion on how to cure the problem? I unfortunatly dont have the 3.60~59 version any longer.
/JR
@jrf1 moved your topic to the existing post about losing BT with higher firmware. See my post above yours. The choice is to roll back to v3.55 and if you have an older Cerbo fit a BT dongle. There is a section about this in the manual.
Thanks @pwfarnell, my cerbo is of course an older, HQ2146. I’ll try to fit a BT dongle since I have slot left in the hub and one in the cerbo. Are there any recomended dongles?
Cheers,
/JR
I use a TP Link UB400 successfully but this is from 2021 on my older Cerbo. This is discontinued I believe but @ricardocello reports success with the newer TP Link UB500 in post above above.
There is an older thread on the community archive but the listed devices may no longer be available.
