Hello, I am new to this community and to Victron. i have a phoenix 12|1200 inverter and a Bluesolar mppt 100 | 50 charge controller. Can I monitor both devices with one bluetooth dongle? How do I connect everything correctly?
I am interested in monitoring the output of my panels, charge/discharge of the batteries, and consumption of my off-grid house.
@arstrube
No you need two BT dongles. One on each device.
The dongles connect to the VE direct port.
Monitoring your battery State of Charge requires a smart shunt (has its own Bluetooth) as the Phoenix only uses voltage.
The other option is a Cerbo S and ve direct cables. Not sure how that will pan out cost wise where you are.
Thank you Alexandra. I am beginning to wrap my head around this… Currently, there is a chinese TR16 battery capacity meter which has a normal (not smart) shunt. I will ask a local technician about how to proceed from there; obviously there is much more to it than just connecting a bluetooth dongle…
I have put the dongle on the MPP and it works more or less fine for monitoring the battery.
My inverter, however, doesn not seem to have VE.direct. Instead, it has a green connector for two wires that I don’t know what it is for. According to the manual I downloaded, there should be a VE.direct in that place. Perhaps I have an older model?
The only thing that occurs to me is to put a standard electricity meter in the power outlet where everything is plugged in.
With that, I could at least manually establish some values for my power consumption.
It is a shame the Victron BT dongle doesn’t have any data logging. For the price I would expect 30 days of data. ( The BM2 12/24v battery monitor logs 30 days of data and can save/export as a .csv and costs approx £15 or so.)
So, is there any third party app which would log the data received in the Victron Connect app??
You need a Bluetooth dongle for the 100/30 smart mppt charge controller? Doesn’t it have one built-in? Can my controller connect to my Phoenix 24/1200 the same way two controllers can?
