Blue smart charger ip22 update
Hello
The other day I noticed that my charger doesn’t have the quick Bluetooth readout. After some searching found that it comes with the newer firmware.
The problem is that it doesn’t show the possibility to update and manually it says it is up to date.
Mode button works, lights look normal and already tried with an other phone.
Dieter
Solved, in a way.
Er zijn blijkbaar meerdere versies met een wissel rond 2021, modellen ervoor, zoals die van mij, worden (voorlopig) niet geupdate.
