Best registers to Enable/Disable multiplus via Modbus?
Hello everyone, I would need your recommandations on a specific subject, I hope you will be able to help me! :slight_smile:
I’ve recently installed in my house a Multiplus 2 combined with existing solar panels (Solaredge inverter) and 4 Pylontech batteries for ESS purpose, everything seems to be working well!
My wife has an electric car and she’s using a Wallbox charger with current sensor which is able to use only the production from the solar panel and as you can imagine when the multiplus and the EV charger are both connected/working, they create some concurrency issues because both try to use the electricity generated by the solar panels.
To solve this, I managed to create an integration with Home assistant, so when EV charger is plugged in the car, I changed ESS settings through modbus, registers 2704 & 2705 to limit multiplus charger and inverter power to 50w.
It works but it’s not perfect, it seems the regulation takes some time to reach the new limits, I also tried to set 0 watt on both parameters but the multiplus is doing a weird noise, I guess it’s not a good option.
Reading at the Excel file with all registers available, I see there is multiple registers named /Mode where it seems I can turn off by software the system but I don’t feel confident to “play” with them. :smiley: :smiley:
What I think could be interesting for me to disable/enable the multiplus in a soft manner when our car is charging:
  • Inverter on/off/eco (register 3126): on/off/eco
  • Switch position - Multi (register 4531) : on/off
  • Switch position - VEBus (register 33) : on/off
  • Charger on/off (register 2317) : on/off
Do you know which one would be the most appropriate to enable/disable the multiplus operations and if it would be safe to use them? (I don’t want to have inconsistent state or reset everything now)
Many thanks for your help,
Benoit
MP2 is a VEBus device. Try 33.
But all that it’s powered by MP2 will turn off this way… Is this OK?
Thanks Alex!
I think I need a solution where multiplus remains powered.
I already played with the remote control physical connection available on the MP2 panel and a relay but it’s a little bit rude for the electronic of the MP2 to shutdown it this way.
The main problem of this is when the EV charge is complete, the relay is turning on the multiplus back but unfortunately ESS is not restarting. I suppose this is because the battery and cerbo GX are remaining powered all the time (even when the multiplus is off) and they enter in a kind of fault state and I need to restart them to make ESS working.
Do you think it’s safe to play with the registers I mentioned (3126 & 2317)? I can do some testing but I don’t want to do a big mistake.
Thanksss
I believe those registers refers to different devices / hardware.
3126 - com.victronenergy.inverter - VE.Direct inverters & Inverter RS
2317 - com.victronenergy.charger - AC chargers.
Also take a look here: dbus · victronenergy/venus Wiki · GitHub
To be honest, maybe a small schematic of your installation could be a good thing, in order for us to better understand what you want to accomplish…
Are you also feeding to grid?
Hello
@benmu : Did you find a viable solution? I’m also trying to disable the charging and discharging of the pylontech batteryies on my 3 phase multiplus II system.
I also have Solaredge on AC IN (alternatively on AC OUT 1 when switching to “off grid”). My Solaredge has a DC-coupled BYD LVS battery and I don’t want the batteries to charge / discharge each other.
Thanks!
I stayed on my solution to change the registers 2704 & 2705. Not perfect, but it’s working. :slight_smile:
Thanks, will try this.
It’s not the exact answer for all situations :slight_smile:
Here is what I do
Firstly I use MQTT since it is faster than Modbus
The flow I use is: When the car is charging change ESS state to Keep batteries charged and then change to Optimized without BatteryLife when the car stops charging. (I do this because when the car is charging the electricity is cheap)
That may not work for you scenario but you could for example limit the inverter power output instead
Hey, can you share the register and values you are using please?
I see multiple options but most relevant seems to be “ESS Mode” 4609 with values:
  • 1 for self consumption
  • 2 for keep battery charge
They are the ones you are using?
With MQTT the format is very different
To set the value you publish to (notice the use of W at the beginning)
W/your VRM id/settings/0/Settings/CGwacs/BatteryLife/State
with a payload {“value”: 9} to keep batteries charged
Change the payload to {“value”: 10} for Optimized without battery life
You can use MQTT explorer to find the exact paths in a system
Thank you, I just changed the setup.
Now, when EV is charging:
  • Register 2705 to 1, to limit battery charging to max 1 amp (50V → 50W)
  • Register 2900 to 9 to keep battery charged, disabling inverter (10 to normal operations)
I’ll keep an eye on it the next couple of days.
I am trying the same as you, finding out which register I could use for:
  1. disable discharge battery (while loading at night the electric cars)
  2. force to charge the battery (when the spot prices at night are extremely low)
the register 2900 seems ok for me, as the excel list says:
0=Unused, BL disabled;1=Restarting;2=Self-consumption;3=Self-consumption;4=Self-consumption;5=Discharge disabled;6=Force charge;7=Sustain;8=Low Soc Recharge;9=Keep batteries charged;10=BL Disabled;11=BL Disabled (Low SoC);12=BL Disabled (Low SOC
But it also says in the remark column:
Use value 0 (disable) and 1(enable) for writing only
I don`t really understand that.
Have you succeeded with 2900 ?
And why do you need register 2705 ?
as described in the remarks with:
ESS Mode 2 with DVCC – Maximum system charge current. -1 Disables.
Thanks in advance for any help.
Hey,
register 2900 is working for me, I’ve checked the remark field and I’m not sure I understand it. Maybe they want to explain 0 and 1 can disable and (re)start the system, but I don’t want to be the person testing it :smiley:
In my case, when my car is charging, I just want to pause operations from the multiplus perspective, no charging or inverting. Register 2900 disable inverter and register 2705 limits charging to the minimum, which I think is 1A.
