Best battery for múltiplus 2 system?!?
In your opinion, which is the best battery for a system with Multiplus 2 48/5000/70?
Dyness DL5.0C 5.12kwh or PYLONTECH US5000-1C 48V 4.8kWh?
Any other alternatives?
Plenty of different batteries out there. Depends on what your local dealer has, and how good the support is.
@JorgeNeves In the near future I suspect the Pylontech remote firmware update will make it into an official release, which may be something to consider ? You will however have to provide the firmware files yourself. Battery Compatibility [Victron Energy] is a good place to start.
Thanks for tour help.
I’ve been looking at the stores closest to me, and the most affordable ones with good support are the two I mentioned, Pylontech and Dyness. The Dyness offers a little more capacity; I don’t know if it will make a significant difference, but it’s also the cheapest, although the price difference isn’t huge.
Make sense , i Will do a search about that .
In my region i ONLY have this two, pylontech and dyness.
Thanks for your help
I have too the Felicity ess battery on my region.
I would go with the NKON ESS battery. Really good components at a very affordable price. The Seplos BMS is compatible with Victron, and the battery comes with an active balancer (I would never buy a LFP battery without an active balancer!). The “Pro” versions come with a fire extinguisher and a heating system.
thanks for your feedback , i will see
Always best to choose something on the supported list. There are many compatible batteries but any issues and the battery manufacturer needs to support you and they aren’t all good at doing that.
The battery is the most important part of a system, pick the best you can afford from whoever will support you the most if you have a problem.
Saving a little upfront can cost you a lot more later.
My recommendation is the Pytes V5.
@ejrossouw The remote FW update for Pytes is currently tested an will also be added.
Do yourselfs a favor and go with 16s packs. 15s will be a problem in terms of compatiblity with other packs (voltage wise).
I’ve not seen a really bad pack for 2 or 3 years now ….
Estou tentado na Pytes v5 , que tem um valor de 949,73€
A ideia é adicionar pelo menos duas iguais em paralelo, a segunda unidade irei comprar mais tarde.
