My system solar charger only ever charged my batteries to 95% unless i used my generator.
2 days ago it started reading 100%
the voltage is still around 28V so no change there.
Does Victron have the ability to change my parameters remotely?
Has something happened a couple days ago that would cause this?
More sun if you are northern hemisphere.
Victron do not update peoples settings as far as I know.
Not enough info to speculate further, would need to know details of solar controller, batteries and the source of the SOC, settings and voltage/current history.
Hiya thanks for help.
Its just that for 5 years solar charge has only gone to 95%
and now its suddenly up to 100%
I’m away from my system to give you more details on it.
Now that is odd after 5 years, battery ageing.just got to a tip point perhaps. Some SOC meters set themselves to 100% on the right combination of voltage and current, which battery ageing would affect
