Battery settings in app for Lead Acid battery, Orion XS
Need some help with battery settings in Victron Connect app for my Victron Orion XS 12-12 / 50 charger
I have a very simple setup in a small van. It’s just the charger and a Lead Acid leisure battery (will upgrade to a better battery at some point)
The battery is a Bosch L5 013
There is no preset for Lead Acid in the app, but i found a youtube video that suggested using: Gel Victron deep discharge (2)
The datasheet i found does’nt have too much information.
It says charging current 9A, so i guess i should set output current to 9A? and input current can stay at 50A?
And it says charging voltage max 14.4V charging pattern UI
So i need help to what i should set Absorbation voltage, Float voltage, Storage voltage and Equalization voltage at.
Id leave it at Victron Gel Deep Discharge 2, since it has 14.4V absorption and the rest sounds reasonable
Limiting the output to 9A will also naturally reduce the input current. Ideally you set the input current limit to what your input cabling is capable of
Thanks for the reply, will try this setting then
dear all, same question for me but in 24 volts. should I just double these value ?
