The reason is one unit is blocking charge or discharge. In your case discharge. Its probably reaching a loww threshold before the others
Try rotation in the bank and see if that helps.
So a bit more info - I have 2 x US3000C and 1 x US2000
Could the US2000 be the issue since it’s smaller and running out of capacity sooner?
The US3000C is my master battery and it is the 1 that has the red light on when min soc is reached (I set it to 30% recently… maybe I must increase it)
The 2000 is the oldest battery. What is the benefit of having it in the middle? (Asking to learn)
I have set my system to keep batteries charged so will leave it for a few days at full charge to see if it helps.
It was getting to full charge daily but for the last 2 months my solar wasn’t working 100% (blown fuse) so it didn’t. That has been fixed 2 weeks back.
@lxonline I kept it at full charge from Friday to Monday and then changed it back to “Optimized with BatteryLife” . Unfortunately it is still doing the same thing.
Is the next step to change the order of the batteries and put the US2000 in the middle?
I have no idea what else to suggest unless you are able to work out which battery is going offline. The light on the master may not be helpful as it is the master
Hi @lxonline I had my installer check out the system and they found that the US2000 was swelling up. They took the battery to the distributor and they have replaced the bad cells.
I have also swapped the batteries and moved the US2000 to the middle of the bank:
