Battery fuse size on a 48v system
Hi, I’m a little confused on fuse sizing within a 48v system. I plan on having 4 renogy core mini 12.8 200ah batteries in series. It states in the charging parameters section on the page that it has a voltage range of 10-14.6V, 14.6x4 is 58.4 so does that mean the batteries will reach that voltage? I’m struggling finding a fuse holder that is greater than 58 volts.
Many thanks
iMaxx has holders up to 70VDC
They got 32V, 58V and 70VDC rated fuses as well
