VRM Installatie ID
494194
Suddenly a number of battery consumption peaks of 50 kW.
This is completely impossible. Who knows how this can happen.
My battery is only 32 kW
Please detail your system.
Its a known issue with some third party devices and mods.
“EnergyFromBattery” is basically the last flow, that is mathematically concluded. It kinda is “consumption/AC-need recorded, that is not seen as sourced from grid, neither from solar”.
That means, your issue is most likely that one of the other 3 figures jumped by that 50kWh.
That leaves us with the grid value. Precisely with the /Ac/EnergyReversed Counter of your meter:
It’s regular value seems to be 50 kWh. And whenever that value turns to 0, the system assumes a counter reset - and as soon as the 50kWh are restored, the system concludes 50kWh feedin to just happened.
And that in above maths means: “That energy mathematically musst have come from battery”.
→ Find the issue, why your grid meter resets it’s EnergyReversed Counter to 0 occassionally and fix that
. It may be a meter issue, but also 3rd party implementation bug or therefore just carelessness on handling readfailurs / disconnects.
If you used a virtual grid meter in node red, make sure you don’t initialize it with defaults, as that will produce a 0 upon every reconnect / reboot / flow deployment.
To verify this is what’s happening, you can visualize that counter in VRM advanced. You may not see clean 0 due to averaging, but if you see spikes down in a otherwise forever incremental graph, that’s your issue.
