I am an electrical and controls engineer working with 400VAC and associated machinery controls systems 24 - 240vac, so I am not a numpty when it comes to electrical systems, but having recently acquired an RV I decided to upgrade the lead acid leisure battery to LiFePo4, so selected a Fogstar 280AH Pro along with their dedicated charger. This is my first experience of LiFePo4.
The vehicle original system uses a multi functional charger Redarc BCDC1240D. This combines the alternator charge and solar charge inputs and distributes to the Vehicle & Leisure batteries when the engine is running and leisure only when it isn’t.
This was a separate small B to B charger CBE CSB-2 that allows excess energy in the leisure battery to keep the vehicle battery topped off at max 4 amps. It turned on at a preset threshold of ~ 13.6v on the leisure circuit, and trickles the vehicle battery.
This device has a poor safety reputation so as part of my Lithium upgrade I replaced the CSB-2 with a Victron Orion Smart 12/12-18 B to B charger. Also with vastly more stored energy available, I felt this was good use of excess leisure energy.
All fine for 6 months until upon first using the RV after the Winter when the Vehicle battery failed. I assumed this was due to the battery itself not enjoying the high Start Stop engine load favoured by Ford transits, et al. I ordered a replacement and put it in the vehicle and checked the function.
I observed the new Victron was in Bulk charge mode, having set it up for AGM cycle via its blue tooth. As the battery was new I just assumed it need topping off.
However, upon checking it the following day it was still in Bulk phase. I wired in a DC ammeter to observe 14amps steady into the Vehicle battery. So by now it had already charged some ~150AH into the new battery (82AH) - or had it ?
I then observed the Fogstar Battery had ceased charging from its mains charger, even though it was demanding charge and was set to charge, it was discharging and down to 69%. I reset the Fogstar by turning the charge mode off and on again and charging from the mains charger re-started.
But the Vehicle battery continued to Bulk at 14amps from the Victron.
I then disconnected the Victron output and hooked up a separate mains battery charger. This also went to bulk but was limited to 7amps (capacity was 8amps), and for several hours stayed there, but then moved to Absorb, but would not move on to Float. The Vehicle battery terminal voltage was stuck at 13.3v, although it did slowly increase overnight up to 14.2, and occasionally the mains charger would briefly move to float mode.
I then disconnected the battery +VE with the charger direct to the battery and the new battery immediately went into float mode. Clearly a side load was acting, and this was likely the Lithium battery acting as a voltage source for the Victron, this forming an endless charging loop.
The Redarc has a voltage sensing input from the Alternator D+ terminal. It seems the Victron was now using the Lithium leisure as a power source to charge the Vehicle, but the vehicle was then putting power back to the Lithium due to the Redarc settings. Because the Lithium has ceased its own external charge, the whole loops cycle was being driven by a slow run down of the Lithium.
I think the ‘load’ absorbing this energy was the heat sink on the Victron and other flow losses in the leisure and Redarc.
I now wonder if the reason the Vehicle battery failed (was dying rather than dead) is because it has been force charging the whole system for months.
I also do not understand why this same loop was not formed by the far lower capacity CSB-2 B to B charger fitted by the RV maker. The RV is Ford transit based. I do have the RV charge system wiring diagram, which I am capable of reading.
I can’t understand why the Redarc, with the engine not running, would allow the Vehicle battery system to effectively provide the Lithium with the energy it has just sent to the vehicle battery charge circuit. Neither can I understand why the same issue did not occur before I fitted the Victron via the original CSB-2.
Now doing my head in, so help appreciated, and I understand I have several differing items expected to work together here.
Could this even be an Alternator fault as surely the D+ should go to 0V when the engine is not running. I have not tested for this yet - trying to work out the way forward to resolve this problem.
Thanks to anyone that can help me get my head around this.
