I can’t find in the manual of the Quattro 120V 10K what is the recommended wire size for the grounding wires.
I am also assuming that in a fixed installation with AC-IN1 has a Generator, AC-IN2 has the GRID, and the AC-OUT-1 has the house load that:
- PE-IN1 and should come from the same ground at the Generator, which is the same as the PE-IN-2.
- That PE-OUT should be connected to a separate ground bar?
- Chassis ground is not needed if PE-IN-1 and PE-IN-2 are wired?
Please someone confirm the size of the wires and to where they should be connected.
