I am looking for some advice on MultiPlus 12/1600/70 grounding. I am looking to supply my MultiPlus with DC current using 50mm2 cables as recommended in the manual.
However with regards grounding. I am under the impression the ground terminal shown in the picture is a DC case ground, thus a cable of the same size or one size smaller should be used.
However terminal block does not allow for a cable this size to be used.
Is this infact an AC case ground which would make more sense as a 6mm2 ground cable can then be used in this sized terminal for my AC chassis ground.
Please can you advise me of the correct grounding process for this?
