Autotransformer terminal question
I just purchased the new version (ITR000100102) of the 100amp autotransformer. Are the terminals rated for aluminum wire? Or should I use a few multi taps to connect short copper jumpers?
There is so-called CUPAL clamping material for connecting aluminium conductors to copper.
In accordance with the processing instructions, the connection may need to be protected against moisture ingress.
