My situation: We have a mostly reliable grid and no solar capacity. Mostly reliable because we get one or two winter power outages that have gone up to 10 days each year. No solar capacity because we are surrounded by tall cedar trees. Also, the on-peak rate is a bit expensive compared to the off-peak and mid-peak rates.
My goal: Time shift my power so I am not using the grid during the on-peak rates. Be able to keep the house livable during the winter outages.
My plan (diagram at end of message): Split my main panel into three panels: grid-only, on-peak, and essential. The on-peak and essential panels will each be connected to ACout2 on separate MultiPlus II units. The grid-only panel has the loads that do not need to be backed up. The on-peak panel has things we do without during long outages (lights, dishwasher, microwave, …). The essential panel has the things we need in the winter (furnace, water heater, pipe heater, battery heater, …). The battery is large enough to run the loads in the essential panel for two weeks. It is also large enough to run the on-peak panel for a day.
From what I have read in the documentation and in other community posts, the MultiPlus II units can do scheduled charging - but there does not seem to be a concept of scheduled discharging. (Please let me know if I am wrong on this.)
In order to do scheduled discharging I will have to use node.red to disconnect a MultiPlus II unit from its ACin during on-peak time. (Again, please let me know if I am wrong on this.)
So, does this sound/look like the right way to do this?
