Hi everyone,
I’m excited to share a new anchor alarm I developed that runs as a Python service directly on the Victron Cerbo. The anchor alarm is built to work smoothly with your existing onboard systems, to help automate your anchoring monitoring process.
Key Features:
Digital Inputs Integration: Connects to windlass solenoid (UP/DOWN) via digital inputs for automated anchor position detection.
Integrated Relay Support: Use Cerbo’s built-in relay to trigger buzzers, alarms, or other loads.
NMEA Compatibility: Receives and sends feedback messages, supports control from Digital Switching on your chartplotter, and enables automatic radius calculation using RPM and SOG data.
YDAB-01 NMEA Alarm Button: Supports dedicated alarm button for aubible alarm and quick interaction
Full Cerbo Alarm & Notification Integration: Leverages Cerbo’s existing alarm and notification system.
Remote Monitoring via VRM: Supports Victron Remote Management for notifications and status updates wherever you are.
Advanced Workflows: Integrates with DBUS, MQTT, and Node-RED for custom automation and advanced scenarios.
Requirements & Installation:
GPS Source: Requires a constant GPS feed (either a USB dongle or any GPS source on the NMEA network).
NMEA Network Connection: Recommended for full functionality and automatic safe radius calculation.
Flexible Setup: Configure digital inputs, relay, tolerance, …
How It Works:
When the anchor is lowered, the plugin saves your GPS position.
When your Speed Over Ground (SOG) drops to zero and engine RPM exceeds 1700, the safe anchor radius is automatically computed (if engine data is available).
If the boat drifts outside the safe radius (with a user-defined tolerance), the system triggers an alarm via Cerbo’s integrated relay and/or a YDAB-01 alarm.
Real-time anchor status and alerts are displayed right on the Cerbo main screen.
Configuration is handled through Victron’s Settings service, making customization straightforward and flexible.
Get Started:
Check out the code and installation instructions on GitHub:
https://github.com/blaaaaaaah/dbus-anchor-alarm
I hope this tool makes your anchoring safer and more convenient. Feedback and contributions are very welcome!
Safe boating,
Thomas
