Advice wanted: 2 multiplus 2 sharing a battery?
Hi all,
I have a Victron multiplus II 48 3000 GX hooked to a 7.k2 kWh Dyness B3 battery. I’m using a combination of ESS batterylife mode limited via some node-red logic to minimize conversion losses on too low (< 200W) and too high (> 1500W) power levels Running fine!
Now to optimize even more I’m thinking about adding a multiplus II 5000 which would be sharing the same battery. This way I would have more power at lower conversion losses using the same batteries. I probably need to add some more batteries to meet the minimum required battery capacity but I wonder if this makes sense or not. Your opinion and advice is much appreciated!
