I already have DC in my van with 300W up top and around 900W ground mounted outside which can be connected and disconnected via and Anderson connector. I added the ground mounts for winter however they are not needed now we are entering spring for my daily electricity needs and the 300W is pretty much adequate and certainly will be in the next weeks and beyond until autumn again.
So, rather than have them sit unused, I am now thinking how I could utilise the ground mounted array on my land. I have few desires but a couple I have thought of are water distiller and induction cooking. These would allow use of the large surplus but as such, being a large amount of power I want to use up it seems like it might be time to think about adding AC since higher powered appliances will mostly be AC.
Now I would prefer to make this outdoor setup separate from the van rather than run things in and back out again as it is more convenient not to have to go under the van all the time to connect and disconnect now it is not essential for my basic power requirements in the van. I am still ignorant really of how AC is setup with solar except a vague idea you use an inverter. This is because before I had no desire for higher powered stuff and so just ignored information related to AC.
Also I was afraid of the higher risk with AC. So as such what extra safety precautions must be taken when dealing with it? How much more dangerous is it than a simple 12V setup?
The outdoor array is of voltage of around 73V open circuit.
What I am still unclear of is what extra equipment would be required given the above intended goal of a separate system. WOuld I have to get another MPPT as well as the inverter? If so what voltage should it be if I do not need it to be a specific DC voltage for anyhitng else and just want to convert it to AC? Is it better to get a higher voltage such as 48V in this case? I am still not clear why there are not products that convert straight from ‘raw’ solar DC straight to AC via an inverter? Why is that?
I was also advised I need a battery as well but so long as I only want to use the outdoor stuff in the day I shouldn’t need one should I? Due to it being only during these peak summer months I don’t want to spend too too much on this. So suggestions to keep costs down would be welcome. With that in mind could I also save some bucks by getting a pwm instead of an mppt? I know it is less efficient but it doesn’t need to be super efficient due to the higher output during these seasons if it would still work.
