Hi team,
I had three questions on the new VRM API node function to adjust consumption forecasts:
To change the forecast using the Node Red “Adjust consumption forecast” option, is it necessary to inject all 3 elements (base, hp, ev) for a given offset? When I try injecting only 1 or 2 of these elements, they don’t seem to be “sticking”. Though when injecting all 3, it seems to work fine.
I read somewhere in the code that if you insert all 3, the ‘total’ gets re-calculated but some clarification on this would be helpful. Is the base load shown in VRM simply the calculation ofbase = total - hp - ev? -
After adjusting the forecast, is there a way to retrieve un-adjusted base load? In my example below, for this one hour I adjusted the base load to 2kWh, and the EV load to ~27kWh. I’m a bit surprised to see
vrm_consumption_fcshow the same value asvrm_consumption_fc_adj. When looking at the two EV arrays, the original value is showing in the unadjusted array.
When using the Node Red “Adjust consumption forecast” option, if the incoming wires include other parameters in addition to msg.payload being set to
{offset: ...}, I get a successful API response with the full installation stats, but the adjusted values were ignored. This may be user error…
I have a flow that first pulls the VRM DESS “installation stats” (to get the forecasts), which then goes through a function that outputs a newmsg.payloadcontaining the offset object. I had to spin off the call to “Adjust consumption forecast”, to its own “clean” path for the API call to succeed (which returns only a success message, and not the new installation stats).
This is more of an observation than a question…
