Adding second batteries with JK-V5 BMS alongside existing BYD battery
My ESS system currently consists of a Victron Quattro and BYD Premium LVL 15.4, plus a few DC-coupled Victron MPPT solar charge controllers.
I am looking to significantly extend my storage capacity, adding a set of DIY batteries. The BMS of those batteries is JK-V5 based. (Currently looking at EEL 48V 16S Server Rack V5 JK BMS DIY BOX Built-in Smart BMS stackable type EU Shipping or similar, planning to add at least 2 15kWh modules).
I have read on the forums that it’s fine to mix batteries as long as they are the same chemistry. I am also assuming that I will keep the BYD’s BMS connected and “in charge” and not connect the data side of the new batteries. Is this correct? If so, would the system “just” work and simply charge/discharge at a slower rate, with the Victron components of the system being none the wiser of what is actually happening?
Also, I was also thinking about adding a contactor between the existing busbar and the new batteries, to be able to disconnect them based on a variety of safety-related criteria (though I presume the JK-BMS would disconnect the individual batteries if any of the current limits is breached). Is that overkill?
Yes, you can mix batteries of the same chemistry. No, you should not use closed-loop battery communication when using incompatible BMS’s. I would disconnect the BYD comms and use a Victron battery monitor to keep track of battery SoC, etc. You would also lose much of the DVCC functionality.
There’s nothing wrong with the approach so long as you use a Victron battery monitor and charging settings configured natively for each charging device.
@petr_io
you can mix and and aggregate BMSs with two solutions:
  • serial battery
  • battery safety controller
Very useful, thank you!
With the serial battery, I would then see the DIY battery in Cerbo GX as it’s own device, alongside the existing BYD battery, is that correct? And I can then select the BYD as the “controlling” BMS to retain all the DVCC functions, right?
The BSC is also a very interesting project, it seems that it could be set up to monitor whether the BMS is alive and disconnect a contactor if it’s not, thus shutting off the entire new battery.
Also take in account that the battery specs should be the same regarding (charge) voltage, cell count etc.
@petr_io
both solutions aggregate data from the batteries/BMSs and create a new virtual battery. In Venus OS you will see the aggregated virtual device, at least for the BSC.
The BSC can also merge data from Neey balancers, additional temperature sensors and create custom rules.
Interesting with BSC is the dynamic charge voltage feature keeping highest cell voltage in a save range by limiting CVL.
I am currently setting up such a system.
Yes, you cannot mix different cell chemistry and/or amount of cells. The solutions will merge data only.
Thank you!
I have just checked, the nominal voltage of the BYD battery is 51.2V, and it communicates via CAN a CVL of 58.4V and CCL 216A.
Both of the parameters seem quite in line with the standard 16 cell setup and also the defaults usually set in the JK BMS (in terms of CVL). Am I understanding it right?
I quite like the idea of the BSC - do you know if it is possible to purchase a kit to assemble one? I’ve checked the official page but they only seem to sell accessories, not the main boards :thinking:
Where did you see serial battery doing that. According to the FAQ no such thing.
Would be nice if it would do so…
After the great links were shared, I did more reading, I concluded that I may be able to get away with not using the serial battery, as the JK BMS should be able to talk to the Cerbo directly via CAN.
So it’s “only” the matter of creating an aggregate battery in (ideally) software of the Cerbo, will keep digging
@petr_io
the main board is sold by Liligo on AliExpress at around 80 EUR.
https://a.aliexpress.com/_ExJrFNG
Case can be printed or purchased from the shop.
58V is quite high. With BSC you can send a different value to Venus OS.
Other solution might be a virtual battery with future Venus OS 3.60
Hm, did not know that this feature was under development - would you be able to point me to more information re. Venus OS Virtual battery? I’ve tried googling but did not find anything but a few mentions in changelogs.
It‘s a Virtual Device in Node Red Victron Paket of Type battery. Check out Test Version of Venus OS Large v3.60-74
