Rankman
(Robert)
16 April 2026 16:13
1
Hello @dfaber .
Hopefully you can help me with this issue.
When i select an ac input like shown in the pictures i cannot set the properties. The dropdown menu’s are grayed out and not selectable.
I already rebooted the GX device en installed the beta versien of node red and after that installed the latest 3.72 version with no results.
Also did an deploy and ignored the error but still not able to change the properties.
It looks like the problem in this topic but the deploy trick does not work…
I have the same on the official version 3.60, I’m a bit worried about this fact
[Zrzut ekranu 2025-06-12 o 17.33.51] **[quote=“Bamss, post:2, topic:35558, full:true”]
[/quote]
**I have the same on the official version 3.60, I’m a bit worried about this fact
Does someone know what i’m doing wrong?
Regards,
Robert
dfaber
(Dirk-Jan Faber (Victron Energy))
20 April 2026 12:09
2
The dropdowns get populated depending on the actual connected hardware in the system. If there is no AC load connected, there is nothing to fill out in the dropdown and it remains empty / grayed out.
An AC load would typically be a Shelly plug.
