Node Red on 3.60 Fresh Install Invalid Property (Service,Path) Errors
Recently I upgraded to v3.60 large to venture into node red. Under the column Victron Energy, any node I try to work with has a red triangle showing Invalid Properties for Service & Path. For example, if I add the node Settings and enter the properties of the node, it is grayed out and shows: Unable to access the service endpoint:/victron/services/input-settings.
Are you using a Pi or a Cerbo?
Does the system node do the same thing?
Presume you have Victron devices attached?
Any other modifications loaded? (You can check general → modifications for status).
In the UI, under integrations, nodered, there is a reset to default option that you can try.
If that doesn’t work, manually reflashing the whole GX might help.
Having the same issue on my Cerbo GX running 3.62.
I have no idea what the fix is, but I’m here in case someone has a solution.
Reset to default had no effect.
mostly victron devices attached
This is a Cerbo. All the victron nodes have the same issue. Yes, I have a few devices attached. The only Mod I have loaded is setuphelper but I have tried to disable it and there was no change.
I was hoping there was a config edit for node red I could remap the path for the cerbo. As a last resort I can factory reset and reflash, but im thinking v3.5 and not v3.6.
I may have found the solution. For me the following link solved my issue.
I swear i tried that yesterday with no luck. I did it again just now and it now works!
Thanks for that update on your findings
