6x Multiplus II 5000 change AC frequency between 50 and 53Hz for loads when in island mode
Hello reader,
First the setup: 3-phase domestic system with 2 Multiplus II 5000 70/48 per phase, Victron solar charger connected to DC (about 5kwp) as well as a DIY battery system. Additionally, ACout has AC-coupled PV installed (about 12kwp) as well as domestic loads.
Situation: whenever I switch “Ignore AC Input” on the Multi to on and put the system effectively into island mode, the Multis start raising the AC frequency to 53Hz in roughly 30sec intervals:
This effectively shuts down the AC coupled PV, as I suppose is the intention of the system. But: why? The battery is not full nor at voltages close to those configured for cutoff. I have the BMS even issue a “charge request” as if empty yet the Multis keep shutting out the AC PV supply (when grid connected, this immediately has the Multis pushing every electron they can get hold of towards the batteries). I can see no configured reason why the system would think it should regulate the AC PV down?
The DC coupled Vicron Charger does not get regulated, it keeps providing current.
So: what am I missing?
I am at loss, so is my dealer. I am hoping someone in this forum has an idea or maybe even faced the same problem?
Cheers, Christian
I had the same issue (3p MP2 10k, 40kWh battery, 13kWp solar): island frequency jumping to 53Hz and then ramping down to 50Hz approx. every 25sec. Turns out software-disabling AC-IN (eg via MQTT topic W/…/Ac/Control/IgnoreAcIn1 or Modbus) is apparently leading to this behavior.
If AC-IN is physically disconnected (eg. at the grid-side breaker), the island frequency stabilizes at 50Hz (resp. increases as needed to throttle down PV inverters).
Best, -Hannes.
Hi Hannes,
read this on the bus and before anything else tripped breakers when coming home et voilà: frequency stable at 50 Hertz, PV keeps producing.
Thank you so much for the reply, this hits the nail on the head!
Might I kindly inquire how you found out? If there is some use case behind this where it should be the way it is, I might accept the behaviour. Otherwise I’d like to open a case with Victron to get this sorted out.
Kind regards,
Christian
PS: nice setup! 30k inverting power on a 13k solar array: why this and how did you convince the installer? Mine tried all he could to convince me that 1:1 ist the ratio I just have to go for.
@pjbfsc Hannes’ post above might answer your question from this post Quattro 48/15000 constantly frequency shifting - VictronEnergy (just found this when I tried to get background on this, maybe it still matters to you)
Hi Chris, glad to hear this fixes your issue! I vaguely remember having seen a post that suggested the MP still tracks grid frequency even when ignoring AC-IN, in order to enable a quicker sync when switching back. That obviously wouldn’t work with the current behavior, so IMO that may well be a bug.
Cheers, -Hannes.
PS: that was a DIY upgrade from 15kWh storage originally installed, similar to what your installer suggested. My plan is to make use of dynamic pricing as that becomes available in order to top up battery from the grid during low-cost hours, in addition to solar.
So to anyone finding this later: this document at VEConfigure: grid codes & loss of mains detection [Victron Energy] describes, well, mentions the behaviour: “To detect a loss of mains, the inverter/charger will constantly try to shift the AC frequency.” It remains to be explained why that applies to ACout rather than ACin, and why it applies in a situation where a loss of mains has already been declared. I have asked my dealer to find that out with the good folks at Victron. I hope I get an answer.
I have noticed that not only the PV inverters will cease working, but it is noticable in household appliances as well, ie fans will speed up and certain lights will become brighter for the short periods the frequency shifts to 53Hz. Needless to say that this renders the mode unusable.
Hello All,
I am facing that issue right now, after a lot of research and nowhere to find any answer, i come across with this post!
Never cross my mind the behavior explained above, for sure after a long battle i might end up solving it.
My setup contain:
3 x MP2 10kva
2 x 10kw growatt at ac out (yes i not, not the best, but we already have it).
8 x US5000 from pylontech
It’s a shame with all the funtionality from MP2 we need to use a external contactor to solve it, we should have some option to sacrifice reconnected time over working shifting phase, when we use a external contactor to cut ac in, we loss tracking of how many times the utilily is down (sometimes 10 times a day), we have anything between 220vac to +250vac, updating to victron solved all our stability issues.
VICTRON GUYS, what a good feature to improve in the near future! For sure is someone struggling with the same situation right in a diferent place.
Also in all the faqs and manuals this is not explained, i read all the ess manuals(maybe not all of them :slight_smile: ), in the PV Inverter Support FAQ in the end, there is some explaination about the 53hz lock, i little note that ignoring ac input will provoque Frequency ripple that would be nice!
Thank you all.
