#46 Data Partition Full - Help
Hi All
Help - I am getting the above error. Everything appears to be working fine - despite the error.
How to I clear this error please ?
Thanks
Tim
Please give us some info of your device/setup that reports the problem.
More information also here: #46 Data partition full
Thanks Matthijs - I’ll get stuck in that next week. Looks a little complicated for me.
I had the ‘large’ install on the Cerbo. I have just updated the firmware - and selected the normal install. I see, speed reading, the issue is only a problem with the large install. Everything is working OK. Do you think I will be OK to go sailing with this alarm ??
Hi @Manyata even after going back from large to normal, there can still be left over “user” data.
You’ve probably installed that. Could be plugins from signalk or pallettes for Node-RED.
I recommend to fix it. If you have a laptop + usb stick handy, then you can do it.
Just try, read closely those instructions and you’ll be fine.
Thanks Matthijs - appreciate the help.
I will let you know how I get on.
Thanks again.
