Can I use a 4th Multi RS solar combined with a 1<>3 phase bi-directional transformer to generate peak charger/inverter power on top of my 3 phase Multi RS system?
Maybe set in stand alone mode, and have a node-red flow following the average power of the other 3 Multi RS inverters.
Once again about the bidirectional transformer. I have one quotation for such device and my brother (more specialist then me) tells me it works.
Quote
Yes, it is, but it must be connected to 3-phase on the primary side. The other way around is not possible. So, converting 1-phase to 3-phase from the grid doesn’t work. But connected that way, it is definitely bidirectional.
What you need (and my wish) is a more powerful RS version (like 8500 watt), even with 3 phase RS6000, maximum continuous power is nowadays too small with heatpump, EV charger, 10kw cooking hob…
