I want to build a setup of 3x MultiRS Solar in PV-only mode. How does/can this setup ensure an even distribution across the 3 phases when feeding back into the grid?
And which Victron components do I need for this setup except the MultiRS it self.
It should be as even as production is (and grid voltage etc.)
A grid meter and maybe a GX would be a nice addition but technically not necessary if you don’t need and control.
But for example the following situation:
RS1 produce 2000W
RS2 produce 1000W
RS3 produce 600W
What will happen as export to the grid:
L1/2000 L2/1000 L3/600
or
L1/1200 L2/1200 L3/1200
I don’t think you can have “PV inverter only” together with 3-phase.
Each device is working on it’s own.
I think you mean by sharing the power over the 48VDC connections?
I would expect the 48V DC/DC converter to be powered off in PV inverter mode, but cant confirm
What each pv inverter produces it will export.
There is no way to ‘phase balance’
